Convertible top problem - Mustang Monthly Forums at Mustang Monthly Magazine
1 |  2 |  Next Page
mk_stangy mk_stangy
New User | Posts: 1 | Joined: 11/07
Posted: 11/03/07
04:44 PM
My '01 convertible top will go down but will not easily go up. I have been told 3 different things: from the dealership, I was, not surprisingly, told that I would need to replace the convertible top motor, but I think the motor must be ok since it functions well enough for the top to be lowered. Someone else said I needed to add fluid as it had leaked out of the cylinder so my two basic questions are, and I apologize for their basic-ness: what fluid do I use and how do I add it.
sarahrose89 sarahrose89
New User | Posts: 1 | Joined: 05/08
Posted: 05/13/08
07:34 PM
I just got a 2001 mustang convertible and the top will not go down. The guy I bought it from said it went down fine last summer and they hadn't tried to put it down again untill a few months ago and when they tried it a few months ago it wouldn't go down. What could it be? would it be a fuse or is my moter bad? or do i just need to add oil to the moter? what should I check first?
LoriHotStang LoriHotStang
Posted: 06/17/08
07:30 PM
I have a 2000 convertible never had that problem but a freind did with his 2002 top motor is a 2-cycle motor one part takes it down other takes it up. the up part may be going out if that's the case you will have replace the motor.
cbs2003 cbs2003
New User | Posts: 2 | Joined: 06/08
Posted: 06/26/08
06:47 PM
I just replaced the motor for my 2003 GT -- the old motor made no sound at all. The top will go down in a hurry, but will raise only about a third of the way up and I have to physically raise it the rest of the way by hand. My friend at a local Ford parts place said the hydraulic lines probably needed to be bled -- that air probably got into the lines when I installed the new motor. He is going to furnish me with a copy of the instructions on how to bleed the lines and I will update you with the process when I'm through with my car.  The motor was relatively easy to remove and replace (after a little bit of trial and error), but it is a little greasy / messy. Make sure you have towels under the motor when you disconnect and reconnect the hydraulic lines.
Stay tuned ......
cbs2003 cbs2003
Posted: 06/26/08
07:15 PM
Check with your local Ford dealer and the parts dept should be able to give you the kind of fluid to use. My friend who is the parts mgr at a local Ford dealership told me to use Mercon in my conv. top motor. I have a 2003 GT but yours might use something different. I would check with the Ford parts place just to be sure.
Where to put the fluid: if your motor is like mine, the motor is two-toned -- one end is silver and the other a brass-like color. There is a black rubber "plug" in the end of the silver part, which is the hydraulic reservoir. Pry that up a little to be able to place (I used) needlenose pliers under the lip of the plug and pry it up until it comes out. (the plug looks really oversized and you'll wonder how you're going to be able to get that back in. I put a small slotted screwdriver into the hole in the plug and was able to work the plug back into the hole.) Fill the reservoir up to about a half inch below the top. Then replace the plug back into the hole.
NOTE: After I installed the new motor, the top will go down down really fast, but will only raise about a third of the way. I have to manually lift the top the rest of the way. The Ford parts place told me that I probably needed to bleed the lines, that air was in the lines. My friend is going to copy the bleeding instructions for me tomorrow (Friday) and I will follow up this email to you when I finish with my car Friday.
I hope I have been of some help to you.
Good Luck
cbs2003gt cbs2003gt
Posted: 06/28/08
12:53 PM
I was formerly cbs2003--cancelled previous user name in error .....
I bled my hydraulic lines this morning; the first time I tried to raise and lower the top, it went down quickly as before.  But it was a little slow coming back up.  I bled the lines a SECOND time and now the top goes down and up like a charm!
Here's what the bleeding instructions said:
1. retract the cylinder rods (I belive that means like if the conv top is down)
2. remove the plug on the end of the hydraulic pump. fill the pump with Mercon transmission fluid to the bottom of the fill hole(I stood the pump on the end and filled the fluid to near the top).
3. (on this step, I just raised and lowered my top three times, manually assisting the top completely back up if necessary) connect a 12-volt power source to the motor connector until the the cylinders are fully extended (I belive that means with the top up). then reverse to fully retract the cylinders. repeat this procedure THREE times, ending with the cylinders fully retracted.
4. remove the plug to check the fluid level. fill the pump once more to the bottom of the fill hole.
5. replace the plug.
Remember, you might want to bleed the lines a second time if the top is sluggish at first, as mine was.
If you do not need to replace the motor / pump assembly, you might try to add fluid to the hydraulic pump side of the assembly and bleeding the lines. If that doesn't work for you, and purchasing and installing a new motor doen't work, you may have hydraulic cylinder problems. I cannot help you there as my problem was solved by replacing the motor / pump assembly.  The cylinders will be more difficult as they are located behind the inside quarter panels in the back seat area and in some cases, the stereo speakers must be removed.
I hope this info has helped any of you with conv top problems.
Good Luck ......
mclarenf1-8 mclarenf1-8
New User | Posts: 1 | Joined: 04/08
Posted: 06/18/10
11:40 AM
The fluid that you use would be regular old mercon dot 3 transmission fluid that you can purchase just about anywhere. How you add it is you remove the cover that would be underneath the top when you put it down located behind the seat (how to remove it i am still trying to figure out) and the motor for the top should be located there. There should be a resevoir on the motor it will almost look like part of the motor and a cap or screw to top it off. It is recommended that you fill the resevoir a half inch from the hole where the cap and screw it. Hope that will help you, Alex.
TROJANII TROJANII
New User | Posts: 28 | Joined: 09/11
Posted: 09/13/11
04:29 PM
I just bought a 2003 Mustang convertible, with a leak on the right side (haven't taken it apart yet to check).
Any idea what the leak might be? Don't know if there might be something that commonly gives up the ghost.
Where is a good/reputable place to buy parts for the top (I work in a body shop and checked the local dealer, cylinders and hoses are discontinued)?
Thanks you any replies.
MustangMan MustangMan
Moderator | Posts: 225 | Joined: 08/11
Posted: 09/14/11
07:54 AM
Usually the plastic lines to the top cylinders start to leak at the cylinders themselves and you'll find fluid under the rear seat and/or in the rear trim panel areas.
Check with Hydro-e-lectric for any convertible parts. They have pumps, hose kits, cylinders, etc.
www.hdroe.com
They have hose kits, cylinders, pumps, etc. to get you going...
HTH...
Mark
Mark Houlahan
Technical Editor for:
-Mustang Monthly Magazine
1966 Mustang 289-4V/C4 Auto
1990 Mustang 306/AOD
TROJANII TROJANII
Posted: 09/14/11
08:10 AM
Thanks for the reply.
TROJANII TROJANII
Posted: 09/24/11
02:21 PM
Well, got the new hoses installed, turns out it is the cylinder.  Oh well, less the motor, it will be a new system.
TROJANII TROJANII
Posted: 09/26/11
01:05 PM
Just curious, I have heard on the fluid for the motor, it should be 75%/90% (I have heard both).  Looking at the motor and it's awkward position, how do you know how full it is?  I had to dismount the motor just to get fluid in it (a wiring harness was conveniently loctated right in front of the plug).
waynep7122 waynep7122
Posted: 09/26/11
02:42 PM
i have a trick about working on convertible top hydraulics...
pick up at least 1 and usually three...   5/16 inverted flair unions....
pick up 6 inverted flair plugs....    store you inverted flair plugs in the inverted flair unions...
when you disconnect the hydraulic line from one side of the pump... take out one plug from a union.. screw the union on the hose end and the plug into the side of the pump...   then take out the other line...  move the plug from the end of the union to the other side of the pump.. then you can connect both lines together...   you have now resealed the system..   the motor can now be removed without dripping all over the place...
the lines stay sealed so you don't loose all the fluid from the system...
you can do the same at the cylinder end of the hoses...
this is a real time saver...   and a pump saver...
one of the many parts number is motormite 43162
Inverted Flare Fittings
Item Number 43162
Type : Plug - Steel
Tube Size (OD) : 5/16
Item Number 43377
Type : Union
Tube Size (OD) : 5/16"
Pipe Size : N/A
Brand : Dorman - AutoGrade - Brass-Tite!
TROJANII TROJANII
Posted: 09/27/11
02:22 PM
When the cylinder leaked, it soaked the padding/insulation under the rear seat.  It doesn't look like it would be washable, and I washed a blanket that got some tranny fluid on it without much success.  I am trying to find a used one locally.  If that doesn't pan out, is there another source, or maybe a material I could use as a replacement?
Posted: 09/27/11
04:29 PM
getting transmission fluid out of padding is not easy...
is it the seat that is damaged or just the padding on the floor...???
which insulator portion do you need...
these are ford basic part numbers...   so you can write them down... and visit any ford dealer  or print the page..
11493
Floor Pan Insulator,  Rear Seat, One Piece Design  under 40 bucks ... is the price i found..  but i don't know if its really still available..
1 |  2 |  Next Page
