engine swap/ carb conversion
lentz_z
Posted: 11/28/07 08:06 PM
Ok, so I have a 93 4 cyl Mustang that I will be putting a 302 from an 89 GT in. I am switching out all the fuel injection stuff for a carb on the donor motor. A few questions: Which intake manifold and carb combination would be most practical and easiest to hook up? I want to go with a dual plane manifold? Will the 302 bolt up to the factory AOD transmission that was paired with the 4 cyl? Will I need a bigger radiator? And are there any other things that will need to be changed to make this work? Thanks
