Posted: 04/02/08 08:59 AM
Hey guys I've got a 460 short block complete engine from top to bottom. W/ c-6 tranny, 67 mustang swap headers, and engine mounts. This is the desirable early blocks and high compression heads. Came from a 68 lincoln mark 3. Currently in my 67 fastback. Need to sell to finance a 331 stoker build. motor has about 50,000 miles on it. The lincoln showed 46,000 and in the mustang it's probably seen about 4000 miles. This is stock build never been touched. It is the c-8oe heads and block and crank. I've still got the engine tag from the lincoln rating the motor at 385 horse. The motor runs fine and doesn't smoke. Does smoke a little around header gasket. I can't tell ya anything about the c-6. Tried to drop tranny pan to change fluid and filter but the headers run right under the pan. I'll take 800.00 for the complete setup. However price is negotiable. Pickup in southeast ky. I can email ya pics of the engine still in the car if interested.
Posted: 04/02/08 10:59 AM
Like I said this engine really needs to go. Really don't have room for it. No reasonable offer will be refused.
Posted: 04/04/08 05:24 AM
If you need any more info email me at billywatson1205@yahoo.com
Posted: 04/05/08 07:26 PM
what would i have to do to put in my 67 coupe
Posted: 04/07/08 04:10 AM
With everything that I've got this would be a direct bolt in. I think you may have to modify the tranny crossmember. Other than that you will need to change the motor mounts, which I have and you will need the headers. I have a complete drop in set-up. Like I said this is currently in my 67 fastback so I know that it will work.
Posted: 04/07/08 06:18 AM
can u send me some pics at timbarts@yahoo.com, and how much can it be bored out, im trying to get about 600hp and i want my car to be a daily driver, so what kinda gears can that c6 handle and still be able to get on the hwy every other day?
