furthur67
Posted: 06/02/08 05:19 PM
The car overheated, the water didn't seem to be flowing and was backing out of the overflow, etc., so I checked the thermostat. It came out in 2 pieces, without the copper actuator (which I never found). I replaced the thermostat with a new one and it overheated again. I took the radiator out and it seemed to have good flow and the actuator wasn't in there. I checked the new thermostat by boiling it in water and it didn't open. I bought a 2nd new thermostat and checked in boiling water and it opened (I also checked the 1st new one again at the same time and it still did not open). I ran the car with no thermostat for 45 min. and it didn't overheat, but idles very rough. We took it for a test drive, it drives well at higher speeds but still idles very rough. Could this be a sign of damage from overheating (valves, lifters, etc.) or could some fuel sensor been affected making it run rich?
Posted: 06/03/08 11:59 AM
Well anything is possible further,,,, but it sounds as though its unrelated. I am not that familiar with your engine but the first thing I would check is IAC(Idle air controller). These generally control your idle and they arent that expensive. Make sure you dont have any vacuum leaks(check all hoses-shut them off for test-like brake vacuum booster may be leaking) and then do a fuel pump pressure test.
Posted: 06/03/08 12:01 PM
Those three things cover some ground I know Further,,,,but they will get you started and they probably cause about 75% of the idle problems.
furthur67
Posted: 06/03/08 02:58 PM
Well that gives some ideas, thanks.
It sounds like overheating isn't likely to cause the problem, which was what I was worried about.
Thanks!
Posted: 06/06/08 01:31 AM
Idling problems can be caused by a number of things. What year is that engine? A carbureted engine will have different symptoms and fixes than an EFI engine.
Posted: 06/06/08 02:53 PM
He said it was a 91 Soaring and 1985 was the last year for carbureted mustangs.
Posted: 06/06/08 04:56 PM
Oh, Ok. Then the first thing to check would be the IAC. If that is good, then take it to a Ford house and have them hook it up to their 'puter.
furthur67
Posted: 06/07/08 04:46 PM
I'll check or replace the IAC, then go from there.
Thanks to all for the help.
