Ragnpony
Posted: 06/30/08 01:00 AM
We resently purchased a 65 Mustang that was one on in a KY fair in 1965. 65A3D611T3631 The question is since it's (born) date is 11 June, does it make it a 64 1/2 or 65? What confuses us is that it has all the qualities of a 65..200ci I6, alternator, etc..and the car warranty number is 5F077TF55986. Not knowing much about the Mustang (yet) we'd like to here back from you folks.
Posted: 06/30/08 11:50 AM
I'm under the impression that March, April and May cars were the 1/2 years and later were 65's. I've seen the explaination somewhere but I can't recall where. Take a lookk here for further info:
http://www.classicponycars.com/history.html
Posted: 06/30/08 05:59 PM
Your 5th digit is a D code. Only in the early production Mustangs did they produde a D code low compression 289 V8. In addition,that car was manufactured before August 1 of 1964 making it a 1964 1/2. It most likely has a generator instead of an alternator too.
Posted: 07/01/08 11:58 AM
The inst panl should have a gen and oil light on a gen car and the alternator car should have an amp and oil light. It's probable that even if the gen was replaced with an alt, the inst pnl would have the original light nomenclature
Posted: 07/01/08 07:25 PM
There are some other differences between the 64 1/2 and the 65 as well as can be seen here. However, officially, there is no 64 1/2 Mustang. Your title will say it is a 65. http://www.shnack.com/document.php?pid=31
Posted: 07/04/08 04:07 PM
the first vin number is incorrect... but if it was "born" june 11th, it is a 64 1/2... all dates prior to july 31 1964 should qualify as a 64 1/2. if the correct vin number has a D for the engine code, it would be a 64 1/2 that came with a holley 4 barrel carbuerated 289 CID motor. if this vin is incorrect and has the engine you describe it could be a 65... there are qualities of both it sounds like. and all 64 1/2 were generator powered motors, the alternator could have been an upgrade from previous owner, i would suggest doing some research yourself regarding codings and such.
the first letter is the assembly plant
F= Dearborn, MI R= San Jose, CA T= Metuchen, NJ
07 stands for Coupe model, 08 stands for Convertible model, and 09 stands for the Fastback model
the second letter stand for the engine
A= 289 4V (V8) C= 289 2V (V8) K= 289 4v (V8) HiPo T= 200 1V (I6) U= 170 1V (I6) -64.5 ONLY D= 289 4V (V8) -64.5 ONLY F= 260 2V (V8) -64.5 ONLY
and the last numbers is the serial number representing what unit it is... ex: 254384= 254,384 car that rolled off the assembly line.
hope that helps a little bit, (my car is a 65 coupe made in Dearborn with a 289 2 barrel carb as the stock motor)
Posted: 07/15/08 03:35 PM
You have a 64 1/2 the two giveaways are the engine code and build date. There is no such thing as a 64 1/2 fastback just hardtops and rag tops. Were the 64 1/2 made in Metuchen or did the start in the true 65's?
A lot of early 65's can have 64 1/2 stuff on them. My Sept Dearborn fastback is full of what would be considered 64 1/2 stuff.
Here is another cool website.
http://www.svs.com/zim/mustang/64faq.html
Posted: 07/15/08 07:16 PM
I remember the 64 1/2 as having this: fixed passenger seat, air vent on the driver side had an A on it. They had a generator, plus They didn't have a brake light switch on the pedal, it had a pressure switch off the master cylinder. the inner radiator support had louvers cut into it instead of oval holes. the head light buckets were shaved and hood had a lip on them. The early ones had 260 v8 instead of a 289, thats about all I can remember off the top of my head.
www.allautosmog.com
Posted: 07/18/08 02:08 PM
The 64 1/2 had three engine choices. A 170 CID straight 6, a 260 two barrel V8 and a D code 289 4 barrel low compression V8.
Posted: 07/19/08 09:08 AM
While indeed these are on the 64 1/2 cars some of these were carried over to the 65 models. I have a sept 64 2+2 and it is full of what would be considered 64 1/2 stuff. For example I have the hood, bezels, spare tire tie down ect.
Some more 64 1/2 stuff are horns on the A frame, tail lights with 3 pig tail wires, door switch contact plate, colored door knobs (falcon), chrome alligator seat belts, sill plates edge not rounded and no toe pad on the carpet.
Posted: 07/19/08 09:10 AM
"fixed passenger seat, air vent on the driver side had an A on it. They had a generator, plus They didn't have a brake light switch on the pedal, it had a pressure switch off the master cylinder. the inner radiator support had louvers cut into it instead of oval holes. the head light buckets were shaved and hood had a lip on them."
Posted: 07/20/08 02:18 AM
1964 1/2 and 1965 Differences Differences between the 1964 1/2 and 1965 Ford Mustangs
Page 1 of 1
The official production of the first mustangs started on Monday, the 9th of March, 1964 at Dearborn. Normaly it should be easy to dertermine the build date if you start checking the VIN of a car, but in this case it's not so easy. Ford decided that the early mustang will get the "65" status from beginng and so every serial number started with 5Fxxxxxx instead of 4Fxxxxxx. This caused a 18 month production time for the 65 mustang!
The official transition date from 1964 to 1965 is the 31st of July. The start of the second production of a 65 mustang was the 17th of August. Before that date a total of 121538 early-mustangs had been build. Ford never referred to Mustangs as "'64" or "'64 1/2" models. They were all considered 1965 models. Regardless what the official view of ford about the model year of these cars, there are differences between the first and second production run of Mustangs.
This is an overview to help determine if your car is a 1964 1/2 or not. The car may have all of the items listed, or just a few. This can be due to variations in production lines and parts supply at that plant. Some items can carry over into the 65 production line, as people on the line would use up what they had. There are be other detail items, such as casting numbers, that have been intentionally missed due to space.
Date codes used in this list are as Ford used in 1964 and 1965:
Jan. 1965 = A Feb. 1965 = B Mar. 1964 = C Mar. 1965 = Q Apr. 1964 = D Apr. 1965 = R May 1964 = E May 1965 = S Jun. 1964 = F Jun. 1965 = T Jul. 1964 = G Jul. 1965 = U Aug. 1964 = H Aug. 1965 = V Sep. 1964 = J Oct. 1964 = K Nov. 1964 = L Dec. 1964 = M
Interior Vent knob Driver's side has white "A" on it Horn Ring with only one contact button (65/2) Horn Ring contact plate fits to 64 horn ring Horn brush completes special horn equipment Trunk Mats Convertibles normally had rubber plaid Caps on the door jambs were not painted bodycolor on some early cars Pedal Pads clutch, brake and gas pedal pads do not have indentation around edge for stainless trim Shifter Bezel 64.5 auto shifter bezel dial and console shifter dial do not have red arrows Console auto console bezel does not have raised pointers for the shift position Shift boot plate special for Man. Transmission w/o console option Shift lever special for 4 spd Shifter T-handle smaller one on 64 Door handles clip-on type instead of screw-on Door handle plate special plastic disk Door cranks clip-on type instead of screw-on Steering wheel can identified by the hole for the contact spring Contact plates for door light switches on inside door edge Lock knob different and painted interior color Lock knob grommets black plastic instead of clear plastic Instrument cluster with warning light "GEN" Headliner rods one end is removable on rear two rods Seats Black with cloth in the middle unique in 64 Carpet No toe pad and cut + serged edges on coupe Seat Belts front chrome buckles in alligator-skin style with eye bolt ends Seat Belts rear Not available; no holes or anchors Owners manual different cover and different content Passenger seat not adjustable until 5/08/64 Body & Wheels Radiator Support air vent openings, no holes for mounting horns, voltage regulator holes Wheels 13" 4 lugs only on 170 CID available Wheel cover 13" only on 170 CID available Wired wheel cover with ford crest symbol Styled Steel wheels argent wheel with silver accents instead of charcoal Brake master cylinder two types differ on powerbrake Brake master cyl. cap jar cap stamped with "fill in heavy duty fluid only" Brake light switch mounts in special master cylinder Lines fuel and brake line clamps are screwed to floor, not clipped Hood angled edges not completely folded over Head light buckets have beveled edges to match hood lip Headlights early 64.5 headlights have raised FoMoCo script Rear quarter extension does not have the channel for the rubber seal Hood bumpers have a recessed phillips head screw instead of solid rubber Hood underside of the hood does not have drill holes between vent openings folded over and headlight assemblies are beveled Hood Hinges black not natural metal look Engine Compartment bracket between inner fender apron and cowl cover have extra vertical tab Front Shock Towers no drain in frame rail under shock tower Engine & Transmission Engines V8 - 260 & 289 cubic inch (5 bolt); 6 cylinder - 170 cubic inch Transmission are close bellhousing pattern - no ears; smaller input bearing cover Timing cover V8 include oil filler tube and dipstick tube Waterpump Aluminium and fit's only on early cover Valve cover V8 No oil filler cap Valve cover PCV small opening for PCV valve on passenger side and different valve Valve cover PCV hose hose without turndown to valve and used of brass elbow instead Oil Pan differnet location of oil drain hole Dual exhaust with transverse muffler (before 8/15/64) Mufflers Dual exhaust system mufflers were parallel but no resonators; pipes are turned down Pipe hangers Rear tail pipe hangers for dual exhaust are not through the frame Bellhousing V8 5 mounting bolt holes; not interchangeable with 65 Brake hose brackets Front have a hexagonal cut-out instead of star washer cut-out Kick down linkage rod linkage for all automatic Differential special U-Joint with all 170 CID Radiator hose moulded hose with all 260/289 CID Transmission unique mount insulators with all 260/170 CID Air cleaner filter unique with all 260 CID PCV valve 64.5 uses a brass 90 degree elbow instead of a contoured hos Spark plugs BF42 plugs on 260 and 289, BF32 on hi-po Crank pulley tripple sheave slotted cast iron with all 260 CID Waterpump pulley two sheave slotted cast iron with all gen engines Front drive shaft (HIPO/4spd) before 10/05/64 28 splines Air conditioner compressor different bracket Air conditioner idler special pulley and bracket assembly No convertible reinforcement from fender apron to firewall Gas tank fill tube had 5 slotted holes Gas fill tube hose special clamps without screws Electric Taillight buckets wires to bucket are sealed instead of later snap on boots Convertible top top sides cables with studs and no springs Fuse box All unique (longer) Turn signal switch differnt switch assembly on 64 Voltage regulator Autolite Black or FoMoCo Generator for all 64 1/2 two type for 170 CID and 260/289 CID Generator heat shield for all 64 1/2 without air cond. Generator insulator for all 64 1/2 with heat shield Generator rubber boot for all 64 1/2 mounts over generator Windshield washer pump only one level Heater box no mounting for resistor circuitry Heater blower fan two speed with circuitry inside motor; ground cable Heater control switch two speed with off in center position Horn Relay All with gen; mounts on radiator support Power steering with early eaton pump only with special adaptor Exterior Badges "Mustang" emblem on fender is 4-1/2" long Gas cap without retaining cable Horse and Corral Different retaining screw location Wiper arm winshield wiper has smooth cap instead of flanged Wiper post winshield wiper post has a chromed nut extension Door Outside door felts backing is black not chrome Door striker plate attached for door light switch Distributor has a small oil filler cap Distributor Rotor unique with all 170 CID Distributor condenser unique with all 170 CID Distributor vacuum line unique with all 170 CID Fuel line to carb passes front of distributor with all V8 Oil filter rotunda red without "6000 mile type" Spark plugs autolite BF32 star powerplugs Wires the wirering is completly different; to much to list Yellow Coil unique mounting point beside carb on manifold Starter Solenoid brown body instead of black one Headlight switch special before 8/17/64 Parking light backing cups have no cut-out Pedal Clutch and brake pedal secured with "E" clips Trunk Trunk Mat Gray burtex in hardtops, and speckled grey rubber in convertibles Spare tire One straight bolt mounts in special bracket in trunk. Hold down is slotted for anchor bolt Tail lights Have 3 wire pigtail assembly
For pictures of the differences, please visit Jason's 64 1/2 Mustang Restoration Project at http://www.svs.com/zim/mustang/64faq.html
sdgrant
Posted: 07/20/08 10:01 PM
All the differences outlined in all previous posts do not identify a '64.5 vs. a '65. Even the engine codes cannot uniquely identify a '64.5 because the K code engine began production in mid-June, 1964 and continued through the '67 models.
Here is the bottom line: Dearborn cars with sequence number below 250000 are '64.5; above 250001 are '65. San Jose cars with sequence number below 125000 are '64.5; about 125001 are '65. Metuchen cars did not begin production until February, 1965.
Steve Grant MCA Gold Concours '64.5 Indy 500 Pace Car coupe - 2003 KNOTTS BEST OF SHOW '02 Premium V6 convertible MCA 50336, Concours Certified Judge '64.5 - '66 class
sdgrant
Posted: 07/20/08 10:14 PM
The first series of numbers you posted is not the VIN number, it's the warranty plate numbers, and they decode as follows:
65A - '65 coupe, std. interior 3 - Poppy Red exterior D6 - White vinyl w/ black appt. standard interior 11T - June 11, 1965 scheduled build date 36 - Louisville KY District Sales Office 3 - 3.20:1 axle ratio 1 - 3-speed manual trans.
The VIN number posted is not valid, but should decode as:
5 -'65 model year F - Dearborn assembly plant 07 - coupe model T - 200 ci six-cylinder engine 755986 - sequence number
You have a very late '65 model coupe, not a '64.5
Posted: 07/21/08 01:29 AM
It has a D code 289 V8 engine which was only available in the pre-August '64 models. You have a 64 1/2 Mustang, but your title will say it is a 65.
