badbrad8
Posted: 07/11/08 01:07 PM
I have an AOD shift linkage from Windsor Fox that I am not able to use. If anyone is doing a restomod and needs this shift linkage, please PM me.
Posted: 07/17/08 03:57 AM
If you still have it, what kind of price are you asking?
badbrad8
Posted: 07/24/08 01:54 PM
I still have it. I sent you a PM. Thanks.
Posted: 08/21/08 10:29 AM
Brad, I'm trying to figure out the AOD swap in my 70 convo. Do you still have the shifter rod? The stock shifter will find PRND21, but the detents are way off. If P-R-N work and D is 4th(OD), I can live with it. Is this possible and what parts will I need?
DB
1970 GT350 Clone
Greetings from the 1836 Republic
badbrad8
Posted: 08/22/08 12:35 PM
On the 65, it was to take the shifter from a pull to a push to work the transmission. The AOD transmission requires a 'push' from the shifter where as the standard transmission was a pull. Hope this helps.
hpelayo1
Posted: 09/26/08 01:12 PM
Do you still have the shift linkage from windsor-fox?
