Transplanting old door inside components into new door shells...
66StangDug
New User | Posts: 5 | Joined: 03/08
Posted: 10/09/08
05:35 PM
Has anyone ever swapped old door innards into new door shells?? What is the best process to go about doing this? I am not wanting to just rush into trying it without hopefully getting a little advise, especially with the tension rods. I do not want to bend or damage them...
Any advise would be great!!
Doug
Posted: 10/13/08
11:43 AM
Yes, I'm in the process of doing this myself.
What I've found is that you will find lots of worn out guides and possibly broken components. I suggest you get the old parts out, then catalog what's in need of replacement and obtain them before reinstall. Up front I bought new plastic retainers and window rollers from NPD. Later to find I needed new felt runs. Nows also a good time to replace the vent wing weatherstriping.
whats the "tension rod" in the window you're refering to?
66StangDug
Posted: 10/17/08
06:03 AM
Yeah, that does seem to be a good idea for getting started with it at least.
I appreciate your help. Let me know how yours comes out.
The "tension rods" as I call them are the 4 rods that control the locking, and door opening and closing latch...
Thanks again.
Doug
eric.bower
New User | Posts: 4 | Joined: 05/08
Posted: 10/17/08
11:07 AM
I agree with jlg2002 100%.  There isn't much more frustrating than getting everything put back together then having to tear it all apart a month later to replace something.  It can get pricey to install all new equipment when the old stuff looks ok, but it will save you a ton of time in the long run, and keep you and your car on the road instead of in the garage.
Posted: 10/17/08
12:02 PM
Its pretty hard to damage those rods, but the little plastic retainers take a beating over the years. You should be OK just replacing the retainers.  Also do your self a favor and downlaod and enlarge a photo or illustration of the door guts (NPD has pretty good one in their catalog) . It help keep things in perspective during assy and dis-assy.
66StangDug
Posted: 10/21/08
09:30 AM
So, this weekend I went ahead and tore into the first one. Took me a while to get it all apart and out of the old shell, but it is looking like all I should have to replace on this one will be the door handle spring.
I appreciate all of the help and advice.
Doug
Gydyup67 Gydyup67
New User | Posts: 3 | Joined: 10/08
Posted: 10/21/08
03:51 PM
I am getting ready to do this, except I am using skins vice the whole shell, I am betting, wondering if its a whole lot easier doing this with the skin off, except the locks etc?
Posted: 10/23/08
11:54 AM
Probably not since most of what was changed is attached to the skin. (and not that difficult to get at)
