67 Coil Springs
snowy
New User | Posts: 2 | Joined: 09/08
Posted: 09/21/08
07:53 PM
I need to replace the coil springs on my 67 hardtop and was considering using 620 lb coils. I currently have 5 leaf mid-eye springs on the rear with KYB gas adjust shocks all round. I understand 620 lb coils will give me the 1 inch drop from standard I am looking for, but how hard will the ride become? The car is a 289 with C4 and is street driven.
fordwannabe
New User | Posts: 24 | Joined: 07/08
Posted: 09/22/08
08:31 AM
Did you think about lowering the attachment point for the upper control arm? This will give you about a 1 inch drop in the front and keeps your spring rate the same. Hey it was good enough for the chicken farmer to use in his cars(65-66 shelby's had this modification). It is well detailed in the HOW TO section of this website. Just a thought. Tom
65gtfstbk
New User | Posts: 25 | Joined: 11/07
Posted: 09/22/08
10:01 AM
I've got a 65 fastback that I too was thinking of putting these springs on but my concern was that the ride would be too harsh.  I had even thought of replacing my stock springs with 1" lowering GT/GT350 springs by opentrackracingproducts.com.
How are your 5 leaf mid-eye springs working out for you?  What are they rated at?  How do they ride?
mechanicalguy48
Posted: 09/22/08
10:49 AM
I have the 620 pound springs on my 65 fastback and also the 5 leaf standard eye springs in back. I dont have the shelby drop but I have found no harshness in the ride. It handles well and I even cut out about 1/4 turn on the front springs to get the ride height I wanted. I dont think you will have any problem with the heavier springs at all. I dont use a heavier sway bar with this combo, only because I didnt think it needed it.
65gtfstbk
Posted: 09/22/08
11:21 AM
Mechanicalguy, were your 620# springs stock height before you cut them?
mechanicalguy48
Posted: 09/22/08
02:33 PM
Well they advertise them as a 1 inch drop but they didnt seem to be. I wanted it to have a slight forward rake. You have to be careful how much you pull out because it increases the spring rate and lowers it more then you think for even a small amount of spring cut out. I would not cut out more then 1/4 turn on these springs. But I dont feel any harshness, the ride is fine.
65gtfstbk
Posted: 09/22/08
05:02 PM
I really don't want to screw this up when I buy the parts and make the modifications so if you don't mind I'd like to ask you a few more questions.  Did you make any other modifications to the front suspension like lowering the upper control arms (Shelby mod)?  I've got P205/R6014 in the front and back on my car. I may eventually like to put on larger wheels like 225/R4517s.  I know alot depends What size tires are you running in the front and back?  Do you experience any tire rubbing or bump steer?
65gtfstbk
Posted: 09/22/08
05:15 PM
Actually, the tires on my car are P215/R6014.
Thanks.
65gtfstbk
Posted: 09/22/08
05:26 PM
I just saw your posted reply to Wheel Fitment under the Vintage Mustangs. I think that answers most of my questions.
snowy
Posted: 09/22/08
06:56 PM
Thanks for the replies.
fordwannabe - Hadn't considered the Shelby drop. As the car is only street driven thought I would go with the easier solution. In any case I can't reuse my existing springs (from Pedders) as the left fron has sagged a bit and the guard rubs on the top of the tyre when turning hard right. It's only done this since I fitted the new wheels and tyres (205/60 x 15 - 112mm offset). The old 14 inch tyres were fine. Must be the different offset.
65gtfstbk - The mid-eyes are working fine. Not sure what they are rated at, but they give me the stance I am looking for and the ride is firm but not harsh. I'm a bit like you and really only want to do the job once, hence my question.
User | Posts: 79 | Joined: 07/06
Posted: 09/23/08
05:17 AM
Just a comment about tire size and wheel combo. I have 225/R60-14 all around on Shelby 10 spoke wheels on my 66 GT-350. Slight rub while backing up turning to the left. Started with 205(looked small), then later jumped to 225(seen another 66 at a meet). I'm pleased with the fit. No ride mods other than what Shelby did.
cushman
mechanicalguy48
Posted: 09/23/08
09:46 AM
The single most authoritative article I have seen on wheels and tire size is from Mustangs plus. I have talked with people in the wheel business and they also refer to it. So I am trying to post it here. We will see how it works out.?
If you cant read it let me know.
mechanicalguy48
Posted: 09/23/08
09:49 AM
Well that didnt work. I guess I have to learn how to post pics here.
