Tail ligts don't turn bulbs fine and have power
cegeto
Posted: 11/13/08 04:44 PM
Hi, I have mustang 68 tail lights don't turn on and when I put left or right signal they are flashing at the same time, checked the bulbs and power and terminals, also check the fuse box everything is fine, I wonder if the problem is the signal switch. By the way all front lights and signal are working good. Thanks in advance.
Posted: 11/17/08 02:34 PM
Typically when everything works together it's either bad bulb grounds or the turn signal switch. I'm not sure I understand your problem as 2 issues or one? bad tail lights and signals or just signals? jlg
