67 coupe frame rails
lethal67
Posted: 12/01/08
04:20 PM
I noticed when i got my coupe, the front left outer frame rail had a patch in it.  The bumper support bracket was welded to the patch and the frame.  As i prepare to drop a new motor in i decided to to investigate the patch a little further.  After cut the weld that was holding the bumper support, the bracket, along with the bolts fell right off leaving a hole you can almost put your hand through.  Obviously i need to weld on a new frame rail.  Structualy, i know that the shock tower is very important.  But can the frame rail be removed with the shock tower and inner aprons still intact.  Or do they need to come off aswell.  I have the front supported, and there isnt a motor in the car.  Any help would be appreciated.
lethal67
Posted: 12/01/08
04:40 PM
IMG]http://i460.photobucket.com/albums/qq322/yellow_stang03/rusty.jpg[/IMG]
lethal67
Posted: 12/01/08
04:42 PM
lethal67
Posted: 12/01/08
04:43 PM
ok theres the pic so you can see what i mean.  To the right of the hole is a steel patch.  I cleaned it up by grinding it down before i decided to investigate further
ssgswartz ssgswartz
New User | Posts: 2 | Joined: 12/08
Posted: 12/19/08
05:11 PM
They sell the outer frame rail in either roughly a 24 inch section to repair that or a full length outer rail,the 24 inch would seam probably under your control arm you could do that without disturbing your shock towers.Gregg
lethal67
Posted: 12/19/08
05:25 PM
Thanks, since posting this, thats pretty much what i decided to do.  1st I cut out the rest of that other patch.
lethal67
Posted: 12/19/08
05:25 PM
lethal67
Posted: 12/19/08
05:25 PM
then i fit another rail to it.
lethal67
Posted: 12/19/08
05:26 PM
lethal67
Posted: 12/19/08
05:26 PM
And i finished welding everything together, along with some other patches last night.  I appreciate the reply.
ssgswartz ssgswartz
Posted: 12/21/08
02:53 PM
I'm doing the same thing on my 70 Mach 1,along with alot of other rust repairs.Gregg
lethal67
Posted: 12/21/08
08:20 PM
Its amazing, no matter what you do, rust never sleeps!
