Posted: 11/30/08 04:56 PM
Im in the process of converting my front drum brakes to disc. I am trying to save some money and wanted to know from what year vehicle i use them. Thanks
lethal67
Posted: 11/30/08 05:22 PM
try this webpage out, it will explain everything. http://www.discbrakeswap.com/The%20Granada%20swap%20install%20guide%202nd%20edition%2002.15.2008%20copyrighted%20CSRP%20llc.pdf
jmoudry
Posted: 11/30/08 06:34 PM
I have their kit on my 66 and it worked out great. I would recomend getting new prebent lines or making your own to replace the old worn out lines. Also if you go with the swap 1 kit you do not need to use the suppplied L bracket, the original one is in the correct location (I learned the hard way = extra holes). Good luck this is a well worth while upgrade.
66 289 coupe
lethal67
Posted: 11/30/08 07:12 PM
jmoudry, have you ever needed to replace the pads? will the average parts store granada pads work? just curious, I havent got that far yet!
jmoudry
Posted: 12/01/08 08:52 PM
I have only had the kit for a few months now so I have not needed to change the pads. The calipers on the swap 1 kit are the same as what was used on the vintage mustang disc brake upgraded cars. Pads can be ordered through most mustang catalogs.
66 289 coupe
