'97 Mustang GT Front Right Turn Signal
cr926043
Posted: 02/11/09 09:31 AM
Hello, My Front Right Turn Signal is not operartional, I have checked the bulb and that wasn't the problem. The flasher is working properly on the dash and has increaed in speed when I activate the Right turn signal, the rear is working.I haven't seen any breaks or openings on the wires. Any ideas as to what the problem is? I appreciate your feedback.
Posted: 02/12/09 02:53 PM
You're going to need a testlight or voltmeter and see if you have voltage at the turn signal(TS) plug when the signal is turned on. If you have a pulsing voltage on one of the wires, then check the other wire for ground. You can do this 2 ways, using a ohmmeter or connect your testlight to the batt + and touch it to the TS plug ground, if the light appears you have a groud. One of these is missing if your lamp lights when installed in the other (other) position.
