lights .dash ,under dash.door
hamilton2
Posted: 03/26/09 09:56 AM
none of my 66 lights work body to motor ground wire ok bulbs ok fuse ok whats nexy ?richard
Mil1ion
Posted: 03/26/09 11:10 AM
Which lights..specifically
hamilton2
Posted: 03/26/09 06:15 PM
dash lights door lights dont work . head and tail lights are ok i took the dash and check for power on the bulbs they have power the fuses have power. the right side derect signals front and back wont work also
Posted: 03/30/09 12:41 PM
so hook a jumper wire (aligator clips at both ends) at one end to the light bulb socket base and the other one to ground, it they light up you have a bad ground on the inst panel (dash lights)if they don't light up, may be bad bulbs. door switches go bad, jumper around them, if the lights come on, the sw are bad. if they don't come on look at the bulbs. I also sounds like bad bulbs on the RH directionals, a bad flasher or a bad turn signal switch.
Mil1ion
Posted: 03/31/09 10:08 AM
Faulty Headlight switch ?
Instrumentation lighting is blue/red stripe wiring
hamilton2
Posted: 04/03/09 06:50 PM
hooked up the aligator clip check the bulbs no power to the bulb fuse is good .the door light and the dash lights dont work c.v.r checks out ok. all fuses are ok
Mil1ion
Posted: 04/04/09 03:46 PM
The ICVR is only for Gauges not lights
My guess is the headlight switch is faulty
hamilton2
Posted: 04/05/09 10:44 AM
new head light switch new ignition switch good ground from motor to the body checked bulbs out of the car they are good.theres power to the fuses no power when i remove the bulbs
Mil1ion
Posted: 04/06/09 02:05 PM
How about when you turn the intensity up with the headlight switch knob ?
hamilton2
Posted: 04/06/09 07:25 PM
turn it up turn it down ----- nothing pulled the fuse box out and all the wires are tight good ground behind the dash panel on the dash brace good ground on the motor to fire wall
Mil1ion
Posted: 04/07/09 10:54 AM
So with the battery connected and the headlight switch on ..is there power to the Blue/red stripe wire on the connector at the cluster ?
hamilton2
Posted: 04/07/09 01:19 PM
no power to the blue /red wire to the socket at the cluster checked all b/r wires with bulbs no power the shifter selector light has a blue /red wire it has power there
Posted: 04/10/09 12:54 PM
The headlight switch directly feeds the voltage to the Blue Red wire from a wire that directly comes from the Battery (BLK-YEL wire hooked to the starter relay. That same source of voltage is also the power for the courstey lights thru the 7.5 Amp fuse. I suspect you're missing the voltage going into the headlight switch plug on the Black Orange wire. Let me know if you need a diagram of the circuit and I'll send it to you with mark ups. JLG
hamilton2
Posted: 04/10/09 02:16 PM
the head lights work so does the parking light a diagram will help find the problem thanks
Mil1ion
Posted: 04/10/09 06:31 PM
