Constant Voltage Regulator Wiring - Mustang Monthly Forums at Mustang Monthly Magazine Mustang Monthly
ashtonc7 ashtonc7
New User | Posts: 4 | Joined: 07/09
Posted: 07/01/09
02:30 PM
I am currently restoring a 66 mustang. Recently i was working on the wiring and when i started the car, the positive wire that goes to the constant voltage unit regulator behind the dash burned completely up to where the wire splices. I was unsure to why this wire would have burned. Did this happen because the CVR went bad? Any help would be appreciated. Thanks
Guru | Posts: 858 | Joined: 03/08
Posted: 07/02/09
11:53 AM
Welcome to the Forum. Wires burn when they pass too much current.  This is usually caused by a reduction in circuit resistance (exmpl: 12v / 150 ohms = .12 amps.   12 v / 50 ohms = .240 amps). The most probable cause of the failure would be a short of some kind within the inst. voltage regulator.
