Tensioner on 3.8L 1994 Mustang - Mustang Monthly Forums at Mustang Monthly Magazine Mustang Monthly
RRobaldo RRobaldo
New User | Posts: 5 | Joined: 12/07
Posted: 08/21/09
02:26 PM
Ok guys, My serp belt shredded.  No big deal, just replace it right?  Well, that's where things went bad...
When I lifted on the tensioner, the metal snapped and broke in half, so now I have to replace the tensioner.
I tried to remove the torx bolt holding the tensioner on, and it's head is completely stripped out!
So now, how do I get the bracket holding the tensioner off the car so I can drill out the torx bolt?
Or do any of you have any better idea's to get the tensioner off the car so I can replace it?
Thanks,
Lance.
RRobaldo RRobaldo
Posted: 08/22/09
08:24 PM
Ok, I managed it on my own.  Figured I'd post it here to help anyone in the future who runs into this problem...
I ended up removing the entire A/C bracket, which contains the tensioner.  Then I used my angle grinder with a cutoff blade to slice through the top half of the tensioner, bolt and all.
After that, I was able to pull the tensioner off of the bracket leaving the stub of the bolt still in the bracket.
I locked a pair of channel locks onto the bolt stub and easily removed it.
When I installed the new tensioner assembly, I used a bit of anti-seize on the new bolt so it wouldn't weld itself to the aluminum bracket.  I also used a standard hex cap bolt instead of a torx, that'll make it MUCH easier to remove if I ever have to do this again.
Lance.
Enthusiast | Posts: 355 | Joined: 07/06
Posted: 08/25/09
06:38 AM
Bravo!!!
