Removing slave cylinder on power steering - Mustang Monthly Forums at Mustang Monthly Magazine Mustang Monthly
morryd66 morryd66
New User | Posts: 1 | Joined: 08/09
Posted: 08/12/09
06:40 PM
Removed cotter pin and nut but can't get stud out of center link?  Big hammer didn't work.
Enthusiast | Posts: 553 | Joined: 05/09
Posted: 08/13/09
05:43 AM
Try a "pickle fork" taper stud removal tool available at local auto parts store.
It might persuade that unit to come apart.
Guru | Posts: 936 | Joined: 03/08
Posted: 08/14/09
11:39 AM
Auto-zone has a "puller" tool(small pitman arm /tie rod end) for rent that pushes the stud out of the draglink with press action while resting on the link and by not hammering, I highly recommend it's use.
Belmont1966 Belmont1966
New User | Posts: 33 | Joined: 04/09
Posted: 08/14/09
01:24 PM
jlg2002 is correct. Do not wack the tapered end of the slave cylinder, or the ball stud on the control valve with a hammer. You can wack the outside of the drag link though with a 3 pound sledge (small heavy hammer) and it should fall out. That's Mustang Plus's recommended method. Barring that, there is a special ball joint tool about the size of your fist that has a thin fork on one end and a threaded bolt on the other. I bought one years ago from an automotive shop. It's the tool to use. If you work on your car regularly I suggest buy one and add it to your tool collection. You will use it again down the road.
