1967 mustang coupe 4 lug to 5 conversion
Posted: 10/21/09 03:13 PM
I have a 67 coupe formerly a 6 cylinder with a 302 that i am restoring. I would like to convert from 4 lugs to 5 lugs and from front drums to discs. Can someone please point me in the right direction on this....conversion kits or something. thanks a lot guys!!!
jc65coupe
Posted: 10/22/09 07:07 PM
I would just find a solid donor car and pull the rear end and front spinals from that. Just remember that you will need a new tranny and radiator as well as motor mounts and possible front shocks to handle the extra weight.
There are literally thousands of disk break kits. You just need to pick the right one for your application, be it a racing or a standard street application. That is something thats your decision and as far as a good place to start looking is either at Summitracing.com or CJpony parts either are excelent. CJ's does nothing but Mustang everything and they can suggest some better quality kits and their advise is solid. Summit is a parts depot that has a bunch of great stuff for all cars.
jb1rd
Posted: 10/27/09 06:26 PM
I could be wrong, but I believe the spindles on the 67 6 cylinder are the same spindles on the v8's. If so, then changing the front spindles aren't needed and lots of trouble and headaches will be eliminated. Check it out from some of the guru's here that are much more knowledgeable than I am, but, I believe I read that info on this forum. Any way, GOOD LUCK, never stop horsing around!!!
camsdad1
Posted: 10/28/09 07:02 AM
I did the same thing with my '68 six cylinder. The easiest way is to buy a conversion kit. I got mine from Master Power. The six spindles are not the same as the eight, my kit came with two different sized bearings for whichever you may have so it will work without changing the spindles. They have since come out with a kit that is pre-assembled on a spindle, just bolt it in.
You will need a whole different rear end though and there are several ways to go. You can buy a brand new one, find a used 8 or 9 inch from a donor car, or find an 8.8 inch from a late model, although I don't think that's a direct bolt in.
Anyway good luck on your project.
jb1rd
Posted: 12/22/09 08:15 PM
I suppose that squis and I need more time in the research lab. Hope all this works out for you, you need really good brakes, I'd also suggest using power booster also, I have manual stoppers and you can't stop about thinking where you want to stop at anytime, cause it takes all the muster to get these things stopped sometimes. Happy horsing around!!!!
squis
Posted: 02/01/10 02:19 PM
In '67, the 6 and 8 cyl model's spindles ARE the same regardless of disc or drum. Disc applications used a mounting plate that bolted onto the spindle that allowed the KH caliper to be mounted. The only exception to this may be the Boss b/c the parts guys have noted different wheel bearing part numbers for the Boss model. I personally own a '67 I6 that I converted using OEM style parts while keeping the existing spindles. When I get brake parts I tell the parts counter reps I have a '67 390GT and get the correct front axle parts(disc, caliper, hoses, bearings, pads) every time.
In '68 there was a specialized spindle specifically for disc (I have a set in my garage).
jb1rd
Posted: 02/11/10 07:37 PM
Thanks squis for the update and info. jb1rd
dukester
Posted: 02/16/10 08:49 PM
If any of you guys have any stock 14" OEM plain 4 lug rims, or 1967 Mustang hubcaps, I'd be interested in purchasing them from you. I just bought a '67 that has 15" 4 lug mags, and I'd just as soon have the factory rims and hubcaps.
