Rear side windows
Posted: 01/19/12 03:02 PM
On my 65 rear windows, they will not roll up or down, it look like the rollers are wor out. There are about 6 bolts holding the essembly. Can the whole thing be undone an removed from the big opening at the borrom or what.Help please.
Posted: 01/20/12 08:28 AM
The regulator can come out of the bottom, but if the quarter glass and track need to be removed it will have to come out of the top, after you remove the window scraper from the body.
Most likely it is just the regulator arm that moves the window up and down has a bad roller. Take the regulator out from the bottom (four bolts on regulator, two on the counter track) and inspect that first.
HTH... Mark .
