15X7 RIMS RUB ON CONTROL ARM WHEN TURNING
CFIL
Posted: 06/10/12 07:47 PM
I just purchased 15X7 Scott Drake styled steel rims for my '67 mustang.When I turn the front rims rub on the control arm. The offset is 4 5/8 do I need a different offset or can I use a wheel spacer? Thanks
Posted: 06/11/12 01:17 PM
Yes, its too much backspacing, 4-1/2 would probably work better. Here's a tech article from MM that discusses wheels and tires: http://www.mustangmonthly.com/techarticles/mump_0507_ford_mustang_large_wheels_fit/viewall.html
CFIL
Posted: 06/11/12 07:41 PM
Hi there, thank you for your reply. I will mention the 4 1/2 back space to Scott Drake because their back space is 4 5/8
