65 fastback quartertrim panel - Mustang Monthly Forums at Mustang Monthly Magazine
fritzthecat fritzthecat
New User | Posts: 7 | Joined: 08/08
Posted: 06/25/12
09:49 AM
I can't find what I need to fasten the bottom of my 1/4 trim panels to. I have replaced floor pans and discarded the used parts
years ago.
Along the bottom of these original 1/4 trim panels are three recessed mounting holes. The rear hole mates to a welded in bracket
mounted on the wheel well . The front two I have no idea except to weld angle to the floor. I've looked at hardware kits online
from the popular vendors for these panels but still can't tell what I need to do.
Any advice from someone whose been there will be greatly appreciated.
MustangMan MustangMan
Posted: 06/26/12
06:40 AM
Yes, there is a strip of metal with two holes and speed nut clips attached that is spot welded to the floor in the fastback. This is supposed to be transferred to the new floor. You'll have to fabricate a piece of metal and weld it to the floor right behind the bottom edge of the trim panel, drill the holes out for the panel attachment holes, and then add the j-nuts/speed nuts to the metal strip.
I'm sure if you do a web image search for Mustang fastback floor pans you'll find an image of the area in question...
HTH...
Mark
Mark Houlahan
Technical Editor for:
-Mustang Monthly Magazine
1966 Mustang 289-4V/C4 Auto
1990 Mustang 306/AOD
Posted: 06/26/12
08:12 AM
Mark
Two steps forward, one step back.
Thanks for setting me straight.
Gary
