'65 289 V engine problem - Mustang Monthly Forums at Mustang Monthly Magazine
elgordito55 elgordito55
New User | Posts: 22 | Joined: 09/12
Posted: 10/06/12
09:00 PM
My '65 289 engine developed an internal metallic loud clanking sound which I suspect is a lifter problem or something related to that. Anyway, this requires opening up the motor and replacing lifters, possibly cam shaft, etc.
I have moderate mechanical skills but I have never done internal engine repairs.
Is there a Mustang Monthly article on this or maybe some other links where I might be able to get some guided help? I have the car's manual, but like all manuals, it is too general. I have also looked up information on the internet, but all I get are Youtube short videos on engine performance.
Thanks for the help
Jesus
22fast.ak 22fast.ak
User | Posts: 100 | Joined: 05/09
Posted: 10/07/12
12:21 AM
Hi! I'm sure there is an article here but from my experience you need the repair manual,  You can get the book (or the CD) for around $20 at any of the mustang suppliers.  I got mine from Mustangs Plus.  GREAT book with lots of information.  I wouldn't be with out one!  Mel
54packman 54packman
Posted: 10/07/12
07:00 AM
would pull the valve covers off and see if you have a loose rocker, you may have turn the motor over by hand and check each 1/4 turn for two turns of the crank, check every rocker to see if it loose, if you do find one loose, check the stud to make sure, it have not pulled out of the head. or broken the rocker, or bent the pushrod.
Posted: 10/07/12
06:55 PM
thanks---I do have the repair manual but I am also looking for additional resources
Jesus
Posted: 10/07/12
07:00 PM
@pack man--thanks! I'll keep your suggestions in mind
Jesus
MustangMan MustangMan
Posted: 10/08/12
07:08 AM
Does the metallic clanking sound hollow or more "solid". Check out the story I did on diagnosing engine noises HERE. Get yourself a stethescope or at least use a long screwdriver with the handle resting against your ear to "listen" to various parts of the engine to try and determine where it is coming from.
HTH...
Mark
Mark Houlahan
Technical Editor for:
-Mustang Monthly Magazine
1966 Mustang 289-4V/C4 Auto
1990 Mustang 306/AOD
Posted: 10/09/12
05:45 PM
@Mustangman--- it's a loud solid metalic sound coming from the right bank and more loud in the center--I'll check your story on diagnosing engine noise-
Jesus
